Hi.
I been Looking around these forums I can not find the answer to this question and does anyone know if the stock 1991 Jeep 4.0L IAC motor needs the power resistors on the MS-II board shorted? I know the IAC instruction page says that it might. Will Anythign be hurt if I short them and it is not needed? My IAC moter does crazy things. I have not yet started my engine, I am just doing some checks to make sure everything is good before I try to start it. When I turn my key on (power up MSII) the IAC moter does somethig differant evey time. Sometimes it goes in sometimes it goes out. Does this sound like a power resistor problem or should I be looking somewhere else for a fix?
I have a V2.2 board running MSII with V2.36 code adn using megatune 2.25 for tuning.
Thanks for any help
Dave
Stock 4.0L Jeep IAC motor
I will check my wiring tomorrow. Did you use the wireing as per the manual and the diagrams. So with the curve of the connector on the top, then left to right is 2B, 1A, 1B, 2A, is this correct?
Dave
1990 4.2L Jeep YJ Running MS2/extra Release 2.1.0o, TunerStudio MS Lite v0.999.7 , v3.0 board, controlling Fuel, Spark, Closed loop 3-wire PMW Bosch Idle Valve
Honda CBR 600 F4I Running MS2/extra Release 2.0.1, MT 2.25 , v3.57 board, controlling Fuel, Spark
(SOON) 1972 MGB Still Planning
That is exactly what mine is doing.
I am running the jeep one as well....... but I picked the GM one today.
Doing the same thing.
I started the car......and warmed it up.
I enter step values at the appropriate coolant temp just to test. And I get erratic behaviour.
I am just about to run the wire accross the resistor. Will let you know if it help.
I enter values of 100 sometimes it goes up. Enter 200 goes up.... enter20 a little blip. Sometimes it goes up and down... very eratic.
944 2.5 L Turbo EDIS 4 MS2
My Success Story
My Success Story
hippled take a look at my post ..... near the bottom http://www.msefi.com/viewtopic.php?t=17742&start=170
I had the same thing happening you describe. On the bench it would exhibit some WACKY behavior.
I jumpered the resistor........ it did not help.
As I describe......I bought another Jeep IAC and GM one. I could not get the 2 Jeep IACS working no matter what settings or wiring combinations I tried.
The GM one did work on the first try.
My Success Story
My Success Story
thanks for the info ae1969. It seams that you and I are having the same problem indeed. I think I and going to forget about debugging my jeeps IAC and go buy a GM one. Can you help me with part number or car make/model/year for the GM IAC. Or did you just use the part numbers in and MSII IAC manual?
Thanks for all you help.
Just an update on my jeep project. I expect to have it running buy then end of this weekend(need to calibrate MAT and CLT and get a new IAC motor). I also just tacked together a new custion made skid plate for my gas tank tonight since the old one came out in 3 pieces. So once the skide plate is done and the gas tank is reinstalled and the new IAC is bought I will be ready to go.
Dave
Dave
Dave
Dave,hippled wrote:thanks for the info ae1969. It seams that you and I are having the same problem indeed. I think I and going to forget about debugging my jeeps IAC and go buy a GM one. Can you help me with part number or car make/model/year for the GM IAC. Or did you just use the part numbers in and MSII IAC manual?
Dave
I used the part # in the manual. I called NAPA and they cross referenced the part to a NAPA part #.
The pintle I believe does not extend out as far as the jeep one. I measured mine to come out to ~25 mm with 200 steps and ~14 mm at 10 steps.
I had to make a housing for the IAC for now.
I just realized you actually have a JEEP. Uhmm would be ideal to get the jeep one to work.... but for the life of me I could not get it two work.
It should look like the one in the pic I posted on the other thread. Silver and black.
My Success Story
My Success Story
