VR sensor in 3TC distributor
Click here to enter
Contact a Forum Administrator
CHB
Post by CHB »
there are 2 wires from the VR sensor in my 3TC distributor, one is red and another one is white.
which one is positive and which one is negative?
does any one run a 3T turbo on Megasquirt II?
238ur50
Post by 238ur50 »
i would think your red wire is power and the white is ground
you can hook them up and if they don't work one way switch it, you won't hurt anything
i can also take a look at my buddy's 3tc motor today and try to figure out which red is what
CHB
Post by CHB »
thanks for the information. is ur buddy running a 3TC MS II too? may be u can share the ignition table if u don't mind?
238ur50
Post by 238ur50 »
no he is not, he is running a Haltec, b/c his buddy runs it so he has to run it, i tryed to talk him into a MS but he won't listen to me, but now him and his buddy 1000miles away can't get it to run right and i am like i don't s*** about that high dollar stuff ;)
i could make you an table but it will need to be dyno tuned or ran at the track to get the timing perfect to find that perfect spot
richie
CHB
Post by CHB »
thanks mate!! mine 3TC specs as follow
63cc stock head.
8.0 CR(estimated)
86mm pistons.
looking forward about the ignition map
