MSII v3.0 board, v2.35 firmware on 2002 Jeep 4.0l I6.
I have used an electronic distributor from an earlier model (1999) and made a new vaned wheel for it. On idle it misses on 1 or 2 cyls. Checking the timing with the timing light I found it to be retarded (firing at TDC or thereabouts), so using the trigger wizard I set the offset to show the correct advance (10 Deg BTDC, -9.0 offset) as displayed. Went to take it for a run and it still misses at idle and detonates like mad when even using the smallest amount of throttle. I set the offset back to +20, and the miss goes away, but there is very little power.
Any ideas what this could be???
Weird ignition problem....
