Ok. V3 boards, MS1 - MSNS-e 029 code.
Stock dist locked down. 450cc injectors, 60mm tb, GM7pin HEI.
Ok, I have it idling and I can pop the throttle and not get a backfire or pop, sounds fine.
I idle around 40kPa @ ~800rpm. If I rev past 4k, the stock tach jumps down to ~2k. but MS sees it fine. IF I run under 36deg btdc timing it just pops. on the other starion here, I took a timing light out there and see it idles at ~45deg timing and at 4500 its around 25deg. In the lowend it can goto like 20deg without poping, but over say 3k it will pop/stutter if it isnt at 36+deg.
Heres some links to my log files:
http://www.ilostmymind.com/upload/camer ... 111528.xls
Heres my most current setup with the least popping:
http://www.ilostmymind.com/upload/camer ... 111531.msq
Any help is greatly appreciated!
-Jay
g54b conquest problems.
