does the trigger wizzard apply to systems using edis where as the variable reluctor is not triggering MS-II ? I have set my engin flywheel to 10 aftdc so that I am able to get "0" degrees. I want to be able to retard timing to zero under boost. when I unplug the saw signal, I get zero on the flywheel. ( no harmonic ballancer) under the ignition settings, what should the trigger offset be set to If it has any effect.
Scott
trigger wizard
