Ok..might be a stupid question, but since my car has the vacuum advance (retard actually) only to retard the ignition 10 degrees around idle and the maximum advance at redline would be 38 degrees (centrifugal).
So...whats the point of trying to to tune the 12x12 map, when in seventies, the factory only used 2d map, in this case, 1x 12 map ???
Fuel economy? DOes my driveability get better?....Or does it work if i just put the numbers i get from 2d map ?
Why 3d map, if there is only RPM and angle information?
I think you need to think differently when setting up your spark curve, Sure you can take your 2d stock dizzy curve and program that in, just make all the Map values the same for every RPM combination, But why? You have the added flexibility to have advance or retard anywhere on the spark map, regardless of RPM or manifold pressure.
Making a pseudo 2d map to start would be fine. When you tune to optimise spark you will change it.
I think it's a 3d map of sorts any way, you have vacuum advance, or intake pressure, you have RPM from mechanical advance, and you have the actual Advance that the engine gets, all happening at once, 3d. Just not as "on the fly" tunable as Megasquirt.
