can i use the 1 coil per cylinder setup as on the modern sport bikes with the megasquirt 1 V3.0 board,
its had all the mods to run the crank angle sensor on a mazda mx5 (miata) (the dsm mods)
its firmware is the 029q2 ms+se
if i can, would i wire it any differently than standard?
1 coil per cylinder
1 coil per cylinder
1992 eunos roadster v-spec
stainless tubular manifold
stainless system
fully ported and polished
need help with throttle body issues
stainless system
