Ethanol injectors/pump/regulator
I am in the process of building a 914 engine (stroked and bored out to 2.7 liter). It will have a compression ratio of about 13:1. I kinda built it originally with the intentions of putting race gas through it, but recent aquisitions of brewing equipment has sent me down the path of ethanol. the cooling effect for my engine would be phenomenol also since these engines are notorious for heat associated damage. The question i have for you guys is what adjustments i need to make? What size injectors should i go with? and what kind of treatments should i do the the fue ltank/lines to make it more "compatible"? Also I have an aeromotive a1000 regulator, and i do not know if that is ethanol compatible, plus i need a pump. any comments would be greatly appreciated. I am have not set up the megasquirt system yet is there any changes to that design that i need to do? I am also planning on running a wideband O2 sensor with the inova
Ethanol injectors are ~ 30 - 40% bigger than Gasoline injectors... About the steel tank, just clean it very well and you're good (ethanol takes all the dirt that gas don't). Make shure that you don't have rust on it...
You won't have any problems with plastic lines too.
Is your 914 engine air-cooled ? Here in Brazil most of racing VW boxer engines runs with gas due the high ethanol consumption, so if you don't care about this, go ahead ! (we have ethanol on the gas station )
FYI, you MUST have a fuel pump that can support ethanol !
Cheers
Daniel[/quote]
Cheers
Daniel[/quote]
Turbo 1996 Fox Wagon @ MS4AVP ECU running MS2-Extra !
You can try one from K-Jetronic systems (VW fox pump), people here used to use them on drag racing due it's high flow(nowdays they run with aeromotive), but I don't know how long it can deal with ethanol...
Maybe you can try one from Chevy Flexfuel trucks, I'm pretty shure that a pump that can resist to E85 can run E100 without any issue.
If you don't care about your current fuel pump, just wash the tank, put a new fuel filter (and change every 5k miles). It'll work, but you don't know for how long ... I know people running with stock gas pumps with ethanol for 100.000 Km, but it seems more lucky than any other thing.
Sry about my english.
Cheers
Cheers
Re: Ethanol injectors/pump/regulator
it isbohalrantipol wrote: I have an aeromotive a1000 regulator, and i do not know if that is ethanol compatible
Thanks, I actually talked with someone at areomotive and they said this:
"Many use the A1000 fuel pump for up to 550 HP naturally aspirated, up to 400
HP forced induction. It will last as long as any of the other pumps that
are recommended for alcohol use, even though the A1000 is not. Normally you
can get a minimum of one racing season, sometimes as much as 2, before
returning for rebuild/repair."
Sounds pretty bad allthough i do not know if ethanol is as harsh as methanol.
Check with your supplier before you buy and/or switch to a supplier familiar with these fuels.
If they don't _think_ it supports methanol/ethanol or do not know what they are talking about then do not buy.
