one thing is going on now.. wanna ask you guys's opinion
eventually i plan to run ignition control from MS via distributor VR sensor.. but after reading some articles, i plan to use back my OEM ignition system (toyota ignitor and coil).
can i share the signals from the VR sensor between MS and the ignitor? can i just splice the VR sensor wires (red and white), and run 2 wires to MS and another 2 to the OEM ignitor? in this way i can run fuel control from MS and OEM ignition system.
VR signal sharing with stock Ignition system?
