Hello, I`m from Norway and have a chevy blazer s-10, and a firebird intake, 2.8 MPFI. (just to get the injectors etc)
I have ms II, and controlled only fuel at first... Now I want to wire the ignition, but have some questions:
It`s a 4-pin HEI module in my distributor, and I read that on the two wires that comes out of the dist, I can put in on the Hall sensor circuit on MS?? is this correct? I also read lance written that the 4-pin also controlles dwell? how am I supposed to wire/set up MS for this? do it need pull up voltage at the signal input? Stim works fine, but get no rpm with this wiring. Wired the 1. lead to +12 at the coil, and the other to tach input at MS. Sorry for my bad english
Thanks for any help!
Hei 4-pin
