I have Holley's universal 1000cfm throttle body with tps and iac http://www.holley.com/9900-171.asp . I was wondering what to do with iac, because I have Megasquirt V2.2 and if I understand correctly, I can't use iac with it and I should use a fast idle solenoid. Can I just leave iac alone and use fis or should I remove iac completely and plug its hole somehow? My car will be turbocharged.
All answers and ideas are welcome. Thanks for advance!
What to do with holley four-barrel universal throttle body ?
Well, IAC does work with MS v2.2 mainboard, but requries you to have the MSII chip. You didn't mention which chip your running on your v2.2 mainboard. If you are using the MSI chip, you could upgrade the chip only and get control of your IAC.
See here for more details, http://www.megamanual.com/ms2/IAC.htm
Check here, you want the MSII daughtercard. It replaces the MSI chip.
http://www.diyautotune.com/catalog/mega ... -p-86.html - worth $90 IMO just for the IAC control, let alone all the other features and improvments.
Good luck.
Good luck.
1983 Jaguar XJS, 355 SBC TPI powered by MSII/V3 running code 2.684/MT 2.25, LC-1 wbO2, 7-pin HEI ignition
1986 Jaguar XJ12, V12, future project?
