Frankly, I still don't understand this one, but the reason for the setting is explained here:This isn't related to the flash burn issue, but why do you have the max spark duration set to 25.5? (Maybe it's a corrupt value?)
http://www.msefi.com/viewtopic.php?p=12 ... ht=#127501
In the end result, I ended up setting maximum spark duration to 25.5 and spark output 'going low (normal)' on blind faith based upon my read of http://www.megamanual.com/ms2/msd6a.htm
My mind still says that spark output should be 'going high (inverted) since an MSD will work with points, and spark occurs when the points open (i.e. going high).
