Hi
Can anybody help me with the values here?
Idle is with an Ford sierra idle.
Help with idle setings, with 029q ekstra code
Ford sierra Is turbo 88
Turbo t-3 Audi s2 dyser ca 345cc
Megatune 2.25
Msns-s 0.29 Q
ms v 2.2
Megatune 2.25
Msns-s 0.29 Q
ms v 2.2
As Keith says, try different values until you like it. Warmup only is fairly easy to tune and is stable.
I use a sierra valve, but on a Rover V8 so my DC will be quite different. For reference though, my settings are:
idle valve freq 100
cranking 60
idle lower 55
idle upper 5
lower temp 25
upper temp 80
I would expect you to need to reduce the idle lower from 55 down to say 30 ? due to the reduced engine size
idle valve freq 100
cranking 60
idle lower 55
idle upper 5
lower temp 25
upper temp 80
okay, thanx
i tried to wire up the cables to the idle valvu today.
What values will i find on the cable from ms?
+, how many volt?
I messured the fidle and fuel pump wiring, both of them was grounding.. strange..
+, how many volt?
Megatune 2.25
Msns-s 0.29 Q
ms v 2.2
Megatune 2.25
Msns-s 0.29 Q
ms v 2.2
