have msquirt II v3 board and firmware 2.1 abs
my engine is an aircooled vw type one because i dont have a dyno
i would like to see ignition advance tables from other people.
this is not to copy them every engine is totally different.
i need them to know how engines behave so i can conclude some numbers that make sense for cruising, full throttle and idle.
with an engine wich has a 107 LCA cam 276° cam wich idles well
what cures the lousy idle ? mine is almost cured of the bad idle but with further adjusting i think we can dissapear any traces of the cam so which of these works better advancing time or retarding it at idle ?i have vacuum in the 60kpa to 55 kpa region.
does anyone has 4 cil ignition table to share proven ondyno?
<<<<FIREBEETLE 94>>>>>>
