Hi all.
I am a little bit stuck on this one.
I'll be using a MS v2.2 to power the fuel and ignition (Edis) on the rover Ti lump.
I've just come across a little discreetion in the two diagrams relating to the injector wiring.
On the original wiring, injectors 1+4 are twinned but the MS states to twin 1+2.
As the firing order is 1,3,4,2, as I see it, do I connect the injectors as per Rover diagram?.
So the banks are firing alternatively or have I missed something in the Software config in the manual?
Many Thanks
Rover T16 injector firing ? Which diagram please.
Hi Sam
follow the crank !
Wiring isnt going to change your engines
mechanics
follow the crank !
mechanics
Ms1 v2.2 board, Running Mt 2.25 fuel only .Squirting my 308ci powered 76 LX Torana with Mustang 5.0HO injectors and Dry 600cfm Holley carb throttle body. Have a look ?http://www.msefi.com/viewtopic.php?t=19937
