HELP
HELP
Guys i've been trying to get help for sometime now.....I'm installing megasquirt ecu version 2.2, so far i've wired up the injectors and all the fueling, the coolant temp sensor, Air temp sensor, i've cut the out two teeth out of the dizzy to use it as a 12-1 wheel and use coil pack....but I need help on how to install the igniton setup so i can get some spark...I'm reading about guys talking about G1 and G2 sensors but i don't know wat are G1 and G2 sensors, i would like to know which wires I should take from the ms ecu and where to wire them plz help....and tell me wat i need to run me VVt knock sensor and fan.
