Howdy, new here.
This will be on a 95 240sx (KA24DE). I already have the fuel portion of the system setup up. I have it setup to use the 4 point optical wheel inside the distributor. What are some safe default parameters that I can use in megatune so I don't screw anything up? What proceedure do I follow for inital setup (keep in mind, this isn't the 36:1 tooth setup)? I have fuel setup using a setup a friend sent me with the "tooth" settings.
EDIT: Using MSnS-E on V2.2 board
Parameter For setting Dizzy
The key things you need to work on are which edge you are triggering on and adjust the input wiring if needs be and then set your trigger angle.
Take your time to get it right.
With an optical dizzy you have the benefit of being able to rotate the engine by hand and measure the voltages to confirm which edge is triggering. It MUST be the regular one i.e. not on the shorter edge.
