starting to wish id never started this conversion but its nearly done just the megasquirt side of things holding me back and fustrating me in a big way
msns-extra 029q v3
vw 20vt coil on plug wasted spark
first off for the people who have been helping me your all stars and thank you
heres the problems car starts from cold idles nicely when it get hot starts to miss and hunt alot ive set the timing as follows
60-2 crank wheel using vr sensor good rpm signal
with the timing light i set the following
fixed angle 14 deg
trigger angle 83 deg
trig A 5
A return 14
trig B 35
B return 44
when starting its holding the starter back so wont do a complete cycle as if the timing is out(do u understand that
my afr reads good while its not hunting my fuel map is a working progress just need to drive it to set it up now
my spark map is all over the place but on idle its 14deg
as soon as i try to put a little load on the car its miss firing backfiring
spluttering and generaly miss behave
ive spent the last month on this now and its killing me
i though my fuel was over heating but i think its just the heat in the engine bay making it feel that way (filter gets warm)
ive tested the fuel lines and they are ok
please please help me i cant read the manual anymore its embbeded in my mind now
yours truly
Ben
OK I NEED YOUR HELP EXPERTS (pretty please)
