Building your own fuel rail
Click here to enter
Contact a Forum Administrator
sidy
Post by sidy »
G'Day all,
I am looking for some guidance from the group on this questions.. Is
it realistic to construct my own fuel rails (for 4 cyclinder
motorcycles) from soldered coper tubing or is it better to buy an
aftermarket assembly?
Sid Young
Visit Sid's
"Classic Japanese Motorcycle Restoration Site"
http://z900.piczo.com/
Posted by email.
jakobsladderz
Post by jakobsladderz »
I would avoid lead solder (tends to fatigue) but bronze or silver solder should be OK. That said, I have a friend who used copper tubing for water pipes on his turbo and they fatigued and broke (after only a couple of months use so unlikely to be corrosion related) resulting in a blown engine (failure occured on racetrack and the vital sign changes were missed). If this were fuel rail, there would have been fuel spraying everywhere.
I guess I'm saying that steel tubing may be a better bet to avoid the chance of fatigue cracks and subsequent fuel leakage.
Duncan
Exeter: (noun) the nut or bolt always left over after putting something back together (Douglas Adams, The meaning of Liff)
PSIG
Post by PSIG »
There are many brass, copper and steel soldered and brazed factory setups out there - mostly steel. The difference is that they are fully supported so the tubing does not get stressed and work-hardened by vibration. Generally copper is avoided for this reason, although I have seen racing setups using it in short supported T sections. They were bright (nickel or chrome) plated for corrosion resistance.
Steel tubing can be had in a nearly perfect I.D. for injectors and be brazed as many factory rails are. I have scavenged injector cups from brazed OEM rails like this. Once again the brazing is fatigue prone so support it - and the brazing itself makes the steel more brittle over time to a limited degree. This is why aircraft manufacturers no longer assemble steel fuselage sections with brazing.
It's a balance of your skills and your wallet. :)
David
mitsuko
Post by mitsuko »
My first fuel rail was made of brass bungs , copper tube and silver solder .
It's been used for abt a year , then I changed it for an extruded aluminium one .
Not because it failed or leaked , but because it didn't look nice .
There must be some pictures of it in the succes stories .
As long as it's decently secured to the engine block , there's no problem .
Pat
Post by jsmcortina »
Mine are sections of steel tube brazed together. However the aluminium extrusions will be easier to work with and look prettier afterwards.
TT350chevelle
Post by TT350chevelle »
Square steel tubing, 1/2 compression fittings and braze 380.Easy,clean and cheap.Heres the only pic I have of my fuel rails.
http://public.fotki.com/tt350chevelle/6 ... 10002.html
Brad J.
sidy
Post by sidy »
Aluminium... Now thats a good thought!
I can anodise it red so it looks fast also ;)
Sid
PS - Hadn't thought of Aluminium, real asy to work with and easy to
get and to machine any unique fittings...Thanks James
> James
> ________________________________
> My Success story http://www.msefi.com/viewtopic.php?t=8008
> MS1/Extra at: http://megasquirt.sourceforge.net/extra
> This post is at:
> http://www.msefi.com/viewtopic.php?p=130963#130963
Visit Sid's
Posted by email.
Bow
Post by Bow »
You might want to check this out:
http://sdsefi.com/techrail.htm
Bow
garrymc
Post by garrymc »
TT350chevelle wrote:Square steel tubing, 1/2 compression fittings and braze 380.Easy,clean and cheap.Heres the only pic I have of my fuel rails.
Brad J.
What is 'braze 380' ?
TT350chevelle
Brad J.
Here's the link to Braze 380 pdf file.
http://www.lucasmilhaupt.com/assets/bra ... /BR380.pdf
and another link with info on a number of brazing products.
http://www.lucasmilhaupt.com/htmdocs/br ... _free.html
Brad J.
PSIG
Post by PSIG »
I use a similar brazing rod from Lincoln you can get at Home Cheapot for about $4 plus some dip-flux. I prefer to add the dip-flux for better coverage. Mine are usually steel-steel. :D
turbo54
Post by turbo54 »
Is there some advantage to brazing rather than welding? I've made many a fuel rail and I've always welded it.... had never even thought to braze.
Am I missing something or is brazing just a cheaper method (don't need a TIG machine)?
mitsuko
Post by mitsuko »
Brazing has the advantage that the solder or what's it called flows .
And it can be applied with little heat compared to welding , wich reduces
warpage . Also , it doesn't take to much skill to braze or solder .
Mag welding does takes some skill to get it all leak free .
An acetylene/oxygene welding torch offers the advantage
of the metal flowing continuusly , like a bazing process , but
introduces to much heat to the rail .
A tig is kinda best of both worlds . Nicely controlled melt , not to much heat , argon protection . Now that I own a tig , I wouldn't even consider brazing or acetylene welding anymore .
Pat
PSIG
Post by PSIG »
A big plus for low-budget DIY MSers is that brazed factory-style rails can be made with just a $30 MAPP torch kit, rods and simple tools. A whole fuel rail could be made for under $50 including the equipment! Image
David
