57lb injectors too big or not ??
Hiya guys,
I'm having a few idleing problems, i just wanted to check that the injectors are too big or not. 57lb low impediance injectors audi 1b 5 cylinder 2.2L Turbo engine.
Oh secondly can MS2 run low impediance injectors directly??
Many thanks
Dave
Many thanks
Dave
5 Cylinder 10 Valve Turbo
What kind of idle problems are you having? Are you still using the stock ECU for spark and the idle air solenoid? I've been working on a friends Audi 5000 with a 10valve and it doesn't always hold a nice idle with the stock ECU hooked up to the IAS. Megasquirt is only controlling fuel. He's running 42Lbs injectors with no idle problems otherwise, he needs to step up to 57-60lbs injectors though, and from all I can tell it shouldn't be a problem idle-wise.
Re: 57lb injectors too big or not ??
Those should run just fine.quattrodave wrote:... 57lb low impediance injectors audi 1b 5 cylinder 2.2L Turbo engine.
Yes. Both the v2.2 and v3.0 boards can run PWM or you can use inline resistors.Oh secondly can MS2 run low impediance injectors directly??
Thanks guys,
Injectors are siemens 3102 rated @ 2.8 ohms. I measured resistance accross all 5 @ 0.7 ohms.
What would be the best way to run them PWM or resistors??
Many thanks
Dave
[EDIT]
Just done my calculations again,
5x injectors @ 2.8 ohms = 0.56 ohms
4x injectors @ 2.8 ohms = 0.7 ohms
hmmmmm, i think i may have a loose connection on my injector wiring !!!
Many thanks
Dave
[EDIT]
You can run them either way, with or without resistors. As for the injectors being too big, what is your REQ_FUEL now? I was running 42 lb injectors in a 2.0L turbo and I too had idling problems. My req_fuel was down around 1.5 ms, and I think it was just too low to control. So, I dropped down to lower 30's for injectors.
-Patrick-
-Patrick-
'81 Fiat Spider - Turbo charged and MSII'd
'04 SRT4
'04 SRT4
Dave, sure thing.
http://www.subaruwagon.com/megasquirt-A ... 011508.msq
Thats what I think to be the latest MSQ we used. Its for the latest firmware, 029qv2 IIRC. Good luck!
