I am installing dual in-tank EFI pumps for my fuel supply system. These will be running together to a tee with a single hose to the filter forward. Will I need check valves installed between the pumps and the tee where the 2 flows combine? The pumps are out of a 95 Ford F-150. My concern is the stronger of the 2 pumps backfeeding through the weaker pump.
Kurt
Check valves for fuel pumps?
Rotax 912 turbo'd under construction MS2 Extra
2005 Mustang GT, turbo'd, aluminum heads, MS2 Extra
1928 Ford Coupe, 545BBF,671 blower, Squirted by MS2 extra 3.1.0, V3.0 Board
Hi Kurt
Aeromotive has some interesting info on fuel supply =>
http://www.aeromotiveinc.com/help.php Thought I saw something directly related to your question but do not seem to be able to find it now..... bugga!
Cheers
DaveZZ
Cheers
DaveZZ
I agree! My BBK pump is all I need to run my 500hp big block. Running two pumps seems a little odd, especially with them not plumbed in series. I don't undrestang the thought behind the "T" with 2 pumps. It also gives you two possible failure spots. EFI only needs 50psi on average and unless you have a full drag car you just don't need two pumps. Remember the K.I.S.S. method? Keep It Simple Son.
1969 Dodge Super Bee
383 EFI dual 65mm throttle bodies, 36lb injectors
"AS SEEN ON TV"
www.moparalley.org/gallery/hollywood
"AS SEEN ON TV"
Thanks for the link Dave. I did a search for "check valve" and found that they produce check valves for just such an application.davezed wrote:Hi Kurt
Cheers
DaveZZ
Kurt.
Why not run one pump that is rated for the engine's gas consumption?
[/quote]
The pumps I have are free. My fuel cell already has dual sumps. I could go on and on with reasons and excuses. The escense of hotroding is building with what you have.
Kurt
