Ok so what is what here? To me the 13 inHg column would be the "idle" portion of the map and 1 inHg would be more toward ambient air pressure. But when you convert 13 inHg to kPa you get 44kPa? Am I missing something? Is it because this is inHg vacuum?
A.J.
Converting Stock Ignition Map
1999 Saturn SC2 1.9L DOHC 4 cyl NA
MS II Blue Processor w/ 2.686t5 Beta Code
V3 PCB
MegaTune 2.25
Innovate LC1 WB O2 Sensor
OBD I Saturn Wasted Spark DIS
w/ Cooling Fan and IAC
V3 PCB
MegaTune 2.25
