mustang tfi/msd no spark output need help please
hello everyone, here are the problems I'm having right now
the car will not start, getting fuel, but no spark
the crane hi-6r I'm running has a status led that says - power supply fault on initial startup
the screen when ignition on and starting shows rpm and pulsewidth to be 0, both stay pink
where should I start, please help, been too long since hearing it run
Is your ECU set up for a Hall Sensor? If the gauge is pink it is not getting a signal or the signal is corrupt. If PW is 0 and rpm is pink, the ecu is not reading the tach signal. I suggest taking signal from the distributor before the Crane. Make sure the jumper on the circuit board is set up for a hall sensor. See the section of the megamanual regarding hall sensors. I assume you have a Mustang dist or Crane, MSD, Mallory.
1969 Dodge Super Bee
383 EFI dual 65mm throttle bodies, 36lb injectors
"AS SEEN ON TV"
www.moparalley.org/gallery/hollywood
"AS SEEN ON TV"
Make sure you follow the TFI instructions on the MS1/Extra site.
http://megasquirt.sourceforge.net/extra/setup-tfi.html
The output side mods are badly described at present. I'll update them soon.
What about the specified 330ohm resistor to 12v?95roush wrote:when I hooked up the led 17 circuit, I simply put a wire from the neg side of the led, and went to pin 36 on the db37.
If the PIP wire touched the shielding you would get no rpm.the input is tapped into the pip on hte tfi. now if the pip wire is touching hte shielding at all, will this cause me some problems?
Did you do the board mods exactly as the instructions?
So you have a V3 board then?
How about the rest of the input instructions? Did you do them?
The output side isn't really relevant yet as you have no rpm, but if you are using a spark box and the "points" input then just wiring to the LED negative will work.
the rest, ok, this is where I'm at right now,
the hall circuit is installed as per megamanual, the mods on the tfi specific site are done
V3.0 board
We will use the opto input so none of the VR components are actually required, they do not hurt if you have already fitted them though.
Jumper TachSelect to Optoin
Jumper XG1-XG2
Jumper OptoOut to Tsel
Fit a jumper instead of D1
Fit a 1k resistor instead of D2
Remove C30 if fitted.
thats all I have done
the pip wire, I just tee'd into it all the grounds are still there and 12v is still there, the tach or spout was removed
V3.0 board
Jumper XG1-XG2
Check you have 12v at the tfi module during cranking.
Put a volt meter on the PIP output from the TFI (at the module) and with dizzy cap removed, rotate the engine by hand. You should see the PIP signal change from 12v to 0v or 0v to 12v as each vane edge passes the hall sensor.
Also, unplug the TFI module and connect the PIP wire that feeds the Megasquirt to 12v then 0v then 12v. You should see an indication of life in Megatune. If you do it fast enough you'll see some rpm.
Perhaps this is the problem. Cut off the other branch so it goes95roush wrote:the pip wire, I just tee'd into it
TFI -> Megasquirt only.
well tried to spin the dizzy by hand and nothing came out the pip, then checked for 12v at the tfi, the one that has 12v run and start is present, the other, start only had nothing, so I ran a wire from the started solenoid to that one, still nothing, this is on a 95 mustang with the remote tfi, there are 7 wires going to the dizzy and 6 that are at the tfi module, on the dizzy there are 4 grounds I think, which are all connected to ground, there is a green pip, and a gray pip, in the schematic, the grey goes to the ecu and the green goes to the tfi, the other wire is 12v start or run, I'
m starting to think something is wrong with either the tfi or the dizzy, but both worked before I removed everything.
would it be easier for me to switch to a 87-93 style dizzy with the tfi right on the side of it?
gotta figure it out soon, not much hair left to pull out:)
Also thankyou everyone who is helping me out
alright guys, been workin on it pretty much non stop, here is where I'm at:
the msd sparks when pin 36 is grounded-working properly
the MS when 12 is applied registers rpm and the pulsewidth is still not moving, not too sure why - is this normal? but other than that seems to be working, tried playing with the dizzy, no response from either the dizzy or tfi, so my solution is to use an msd pro billet 87-93 with the tfi on the dizzy, I wanted to do this anyhow, and looks like I had no other options, I will update this when I get home from work tonight and have the new dizzy installed, praying it will start.
on another important note - the diy 'MS your mustang" the diagram that has the msd only tfi wiring has the following:
1 pip to MS
2 No connection
3 12v start and run
4 12v start and run
5 no connection
6 ground
now I think the pin 4 should only have 12v when starting and not while running, being a push type start, thats the push, mimicing the pip signal, right now I'm going to wire pin 4 to the starter solenoid, that way only 12v starting.
please correct me if I'm wrong, I would really love to hear it start tonight
1 pip to MS
2 No connection
3 12v start and run
4 12v start and run
5 no connection
6 ground
