Here's my situation. I hope someone can shed some light on this for me. Yesterday, the wire that goes into the MS unit for the fuel pump relay came loose. I re-attached it and now I notice that my fuel pump stays on when the key is in the on position. I used to hear the relay click on, then the fuel pump would prime and then the relay would shut off and the fuel pump would shut off. Now, the relay clicks on and the fuel pump stays on. Does this should like a bad fuel pump relay? Is it coincidence that it happened when the fuel pump wire came loose? Most importantly, will this effect the car when running? I wouldn't think that it would effect the car while running. The only negative effect that I can see is if the car is left in the on position, it will flood the engine. Please help me out. thanks.
-RJ
Fuel pump stays on with ignition in 'on' position!
hi R.J
im getting the exact same problem,. fuel pump runs constantly without priming and going off after 2-3 secs,
if i dissconnect m.s completly the fuel pump dont run, so i know it must be a problem with the m.s
i even tryed upadaing firmware like other did but i dident work.
so far i have not worked out whats the problem, if you find out the problem R.J please post what is was mate.
also is there anyone here that can help us, solve this fuel pump problem
This could occur if the transistor on the main board that drives the fuel pump relay got damaged.
