I blew my EDIS coil today while firing it directly with the coildrivers on the V3.0 board. I probably neclected the chargetime, being 4ms standard in MT.
So, now I have a coil with 0,5 ohm on one side and 0,8 ohm on the otherside. Which leaves me to 1 option, get a new one.
But, I don't wan't to fry it again.
Does anyone know what a reasonable chargetime would be for an EDIS coil ? I have read about the HEI coil whitch should be good in 2,5 ms.
Would it make sense that it fried at 4ms ?
Thanks !
Allmost there... At least it is better running then on carbs and C-breakers.. But that aint hard...
Charge time EDIS coil
Thanks Lance.
Double checked the way it was charged and it should be fine.
I am running on LPG (Propane gas) and was trying to get a decent fuel constant for the injectors. So I kept it running for quite a long period while retuning the maps. I think that is what killed it.
If 2,5ms is typical, I over boosted it with more then 50%. I have learned this can be very harmfull for the unit. And to make things worse, this was an old one from the junkyard.
Better get a new one and set the chargetime to a decent value. I'll stick to 2,5ms to start with.
Whell, installed a "new" coilpack from the wreckyard and played around with the dwell times. The odd thing: I got two Ford EDIS coilpacks and one was running on 1,1ms, but the otherone was not.
Finaly I ended up on 2,5 ms and the VB921 stayed cool and the coilpack was not warm too. So I guess 2,5ms is a good starting point and 4ms is defenetly not for an EDIS coilpack.
Good luck you all !
Good luck you all !
