Ok I have been trying to read all I can about how to control the GM style IAC. I have it all wired up right from what I can tell but all the changes I make to the idle steps table don't seam to change idle rpm. I had it all the way down to 0 and all the way up to 255 for the temp I was at without any luck of change the idle speed. I read some place that you need a H bridge circuit for this now does the MS2 V3.o have this built into the board or do I need to build it in the proto section and wire it in?
MS2 V3.0
92 Saturn SC2 Vortech V1 A Trim
98 Saturn SC2 DP Nitrous
Chripsle...mine did work, WHen I had it. you just need to hook the circuit up right. I didn't use a bridge. There appeared to be a probelm with the older codes where after a minute or two the IAC would just stop working...thry the latest 2.3x code and see if that helps out.
I'm running 2.6 something. If I remove it while the car is running it's going to rev up really hi. Is there a way to check to see if it's working without the car running?
MS2 V3.0
Get an extra one and just plug it in...have someone cycle the key and watch to see if the indle moves. I know those IAC's are a PITA to get out without removing the tbody, so try to find and extra.
