The megamanual suggests to place a 0.1ohm between the emitter & ground of the VB921 to measure the current ramp. In my case, it would be MUCH easier if I can put that resister between MS output and collector of the VB921.
I don't think it will work but can anyone confirm please?
thanks.
Measuring dwell / charge current
Re: Measuring dwell / charge current
This resistance will of course add to that of the coil but it should have minimal effect on the operation of the MS and the coil. Be VERY careful about connecting up the scope IF you place this res between output and collector. The earths of the scope channels are connected so you could end up shorting something and I suspect you will battle getting the scope triggered. It would therefore be better to put it between emitter and ground such that your scope earth will then also be connected to ground.hobieboy wrote:The megamanual suggests to place a 0.1ohm between the emitter & ground of the VB921 to measure the current ramp. In my case, it would be MUCH easier if I can put that resister between MS output and collector of the VB921.
thanks.
Why would you want to do this anyway? You can accurately calculate the coil primary current with the following formula:
i = V/R(1-e^(-R/L*t))
V= volt, R = coil resistance, t = time, L is inductance of coil in Henry. I have measured 3 coils, and they all have inductance of between 3.9 and 4.8mH.
Kind regards
Philip
Philip
I have measured the resistance & inductance already so theoretically I don't have to do this but thought I should verify in real time that the rest of the circuit is functioning properly?
Maybe all I need to do is to make sure the VB921 is not hot - but then I also have a not-so-accurage temp sensor to warn me.
Due to the voltage correct and any discrepancy between the commanded dwell and actual dwell (something of an issue with MS1/Extra at higher rpms and wasted spark) doing the empirical test is valid.Philip Lochner wrote:Why would you want to do this anyway? You can accurately calculate the coil primary current with the following formula:
The V3 board already includes the sense resistor to measure the coil current.
...but overall coil current is NOT the objective to
measure here... it's the rise time of the coil current so
the proper dwell can be set.
The .1 ohm resistor is simply to give you something to
have a voltage drop across so you can measure the signal.
Probing the drain of the of the VB will give you a
differentail back to ground to see the signal. BUT you'll
be looking at an inverted spike rather than a 'rise' in
the scope trace.
do-able... bot not neccessarily as easy to read.
ptegler
On Fri, 18 Aug 2006 08:09:15 -0700
"Philip Lochner" <philip@gpltel.com> wrote:
ptegler@cablespeed.com
www.teglerizer.com
Posted by email.
the scope trace.
ptegler
Paul Teglerhobieboy wrote:This resistance will of course add to that of the coilThe megamanual suggests to place a 0.1ohm between the
VB921.
please?
thanks.
following formula:
Kind regards
Philip
Land Rover Discovery MS-2/V3/2.36/LC-1/4.6 V8i, VR(6
BTDC), TP100, std coil - EDIS install in progress.
Jaguar XJS V.12 5.3, MS-2/Dual WBO/MSD6A/ignition +
fuelling
www.teglerizer.com
Posted by email.
ptegler
ptegler @ cablespeed.com
My Success story: http://www.msruns.com/viewtopic.php?t=21806
Home site: http://www.teglerizer.com/Injected_Spit6.htm
