Im currently using Electromotive XDI coilpacks. In a blurb about the XDI system it says that it charges the coils to 9 amps/its coil drivers are 9 amp units. It goes on to say that the ouput is up to 150mJ for 2ms+.
Im thinking it would be worthwhile to try to duplicate that if possible. So is there a better VB921/similar that is capable of 9+ amps? Or....
Can I use a pair of VB921s to drive each coil, and wire the VBs up as if I was doing wasted COP? That is, two VBs, 680 ohm resistors running off each spark output, but instead of four coils for four VBs, have two coils for four VBs? I would then scope out dwell in the standard way with both VBs going through a single 0.1 ohm resistor to ground.
That should prevent each one from going into current overload, and let me charge the coils to their full potential. Is there a downside to this that im not thinking of?
And heres a pic of the coilpacks in action. I accidentally knocked one of the copper wires away and saw that it could do this, so I took both of them off and took a pic. Yes I know spark length isnt a real measure, but this is a d*** cool pic and goes well with the DANGER HIGH VOLTAGE sticker on the coilpacks
Alternative to VB921 (9 amp capable) OR Two VB921s per coil?
1986 Porsche 944 Turbo
2.7 liter MID sleeved big bore, Wossner pistons, Vitesse Stage 2 turbo, coilovers, various weight deletes, and loads of other stuff.
