How to bypass a GM IAC port or close the valve?
My manifold uses a GM 4wire IAC motor but I am using MSnS-e which does not have that capability. I'm going to use a simple FIdle valve. How can I extend the pintle to hook it up so it does not allow any air to change the idle speed?
Chris
1992 Isuzu Pup with an '02 GM 3.8L (3800) dropped in. Running MSnS-e
I was using a Rochester TBI until recently. I was able to extend the pintle by uncrewing it until it came out, then screwing it back in a turn or two.
As of last weekend, I have an air sensors style 4bbl throttle body with the same type of IAC. However, there is a port on top that appears to be solely for this bypass. So, I think I will just plug it since I am also using MSNSe and and an external IAC.
