I have a 99 Miata that uses a 4 tooth (no missing) crank sensor and a cam sensor that triggers one pulse on the first crank rotation and two pulses on the second rotation. Using RS latches, NAND gates and inverters I can block the crank pulse following a cam event creating a 4-1 wheel signal. Is a 4-1 wheel too course for ignition timing?
Frank
MS II v2.686/MT v2.55
4-1 trigger wheel and MS II
99 Miata
