Coils, recomendations??
Anybody got any high production coils that they've seen work good in a blown 8cyl. single coil application?(MSD does not qualify) Just looking for something cheap and dependable. Needs to be able to work everytime at 35# intake pressure.
Re: Coils, recomendations??
Nothing is cheap AND dependable at 35psig. Seriously, any good waste HO coil set with a solid set of supporting hardware and maybe surface gap plugs at .5mm should suffice. Even EDIS with factory coils and standard gaps will fire well into the 20's so using some standard magic should get you there. I'd stay away from a single-coil setup unless your rpms are very low as the charge time will likely be insuficient at that pressure.bojo68 wrote:... Just looking for something cheap and dependable.
David
