hi guys just a quick question on my bottom pulley i have a tdc mark which lines up when you time the car up ive marked the pulley with tipex every 10deg
so my question is with a fixed angle of 10deg my timing mark should show 10deg btdc i adjusted the trigger angle to 58deg and it seems to idle fine
should i be testing this at other rpms not just idle ??
VW 2Ovt Bottom pulley marks
VW Mk1 Golf Gti Cab 20v turbo msns extra 029q2 v3
vr
my timing is spot on now with a fixed angle it doesnt move it stays 10deg btdc which is good think my map will need tunign slightly apart from that im pretty happy with the timing just wanted to double check
