Switch from EDIS to Direct Coil Control
I've been running EDIS with my car the last year and a half, using the EDIS control module, but I would like to get into flat-shift/launch control and I've read it is not easy/possible with EDIS. Therefore, I'd like to know what is all involved in the switch from EDIS to Direct Coil Control?
I purchased my MS1 unit pre-built and set up for EDIS control, will I have to add a vb921 driver? Then also remove the EDIS control module which the pip/saw are wired into, and wire those directly to the relay board?
MS1 v3 w/edis4
MS1 v3 w/edis4
81 931
-ms1 v3 w/edis
"It's not cobbled, its CUSTOM!"
-ms1 v3 w/edis
Re: Switch from EDIS to Direct Coil Control
You'll need to add two direct coil control drivers - VB921s have been out of production for a while; we're using BIP373s for now. We have an article on multiple ways of dealing with Ford crank triggers here that covers mods needed:
http://www.diyautotune.com/tech_article ... erview.htm
You'll want the mods and settings in "Direct Coil Control Distributorless Ignition on a Megasquirt-I V3.0 or V3.57 Board".
d***, so it looks like I have to uninstall all the EDIS modifications, build the VR circuit, and then do the direct coil mods/jumpers,and buy an additional BIP373.
Then I have questions about the mods for EDIS say "remove c30". Then I would have to find the component needed for c30 and add it back in for direct coil?
Also, how is everything affected wtih the Relay board?
Does anyone/shops allow people to send them an already built board and let them modify it?
81 931
-ms1 v3 w/edis
-ms1 v3 w/edis
C30 is only required for triggering off the coil-negative so you are safe to omit it, plus it is in the hall/opto input circuit which you won't be using.flosho wrote:d***, so it looks like I have to uninstall all the EDIS modifications, build the VR circuit, and then do the direct coil mods/jumpers,and buy an additional BIP373.
There are spare connections running there (I believe) so it should be a matter of wiring the drivers to the required pin and you'll be ok.Also, how is everything affected wtih the Relay board?
If you were in the UK, I would!Does anyone/shops allow people to send them an already built board and let them modify it?
Maybe Peter Florance? (VA)
I ordered 1 BIP373, and I have a VB921 already installed. Should I uninstall the VB921 and replace it with a BIP373? or can I use one of each?
81 931
-ms1 v3 w/edis
-ms1 v3 w/edis
had to make a digi key order so I'm just going to order another BIP373...
This board was configured for EDIS and it does not have a VR circuit. So I ordered the components for the VR conditioner circuit.
I'm assuming I must UNINSTALL the jumpers related to the Hall Sensor (edis) circuit including:
Jumper XG1 to XG2 on the bottom side of the PCB, near the 40 pin socket,
Jumper OPTOIN to TACHSELECT on the bottom side of the PCB, near the DB37 connector, opposite the heat sink.
Jumper TSEL to OPTOOUT on the bottom side of the PCB, near the center.
My XG1 does not have a jumper to XG2. My XG1 is jumpered to TACHSELECT
Other jumpers already installed by builder(not me):
IGN to Q6 with a resistor that is also soldered to the bottom side of Q6 and goes to +5v above proto area
S12C to D1 which has a jumper installed across D1 on the top side
TSEL to OPTOOUT
JS11 to 5v+ above proto (launch control)
TSEL to OPTOOUT
81 931
-ms1 v3 w/edis
-ms1 v3 w/edis
If you're not comfortable doing it you can send it to me, I've done many. You can PM me for more information.Does anyone/shops allow people to send them an already built board and let them modify it?
Scott
Graduate of EFI University.
I've decided to move forward with the mods. Still waiting for the two BIP373 to come in
I ordered a space VR sensor pigtail and the DIY shielded wire setup.
For wiring this up. I've got:
VR sensor (White/Positive Signal) to PIN 15 on Relay Board
VR sensor (Green/Negative Signal) to PIN 14 on Relay Board
I'm still going to use the EDIS4 coil pack I have.
The ignition coil plug has 3 connectors 1 is Coil A and 3 is Coil B and the center wire goes to the EDIS control Module(Which goes to switched 12v+).
I wired the 3 connector coil plug with the center wire directly to a switched 12v source and
Spark A goes to pin 36 of the DB37, which traces to Terminal 11 on the relay board so the wire for Coil A on the ignition coil connector (wire 1) goes to the relay board at terminal 11.
Spark B goes to pin 31 of the DB37, which traces to Terminal 10 on the relay board so the wire for Coil B on the ignition coil connector (wire 2) goes to the relay board at terminal 10.
Does this stuff sound correct?
So I removed the EDIS control Module.
81 931
-ms1 v3 w/edis
-ms1 v3 w/edis
Sounds correct for the wiring external to the controller.
Got everything put together.
When I installed the jumper from TSEL to VROUTINV, I used "VROUT" because in the Megamanual it had that and in parentheses VROUTINV.
I configured all the settings accroding to distributorless settings here: http://www.diyautotune.com/tech_article ... erview.htm
None of the LEDs on my MS unit lit up so I changed "Set Spark Output to yes" and changed to "No" and then the two ouside LEDs would light.
Unfortunately they I did not get an RPM signal in MSDroid.. But now I'm thinking I might have the VR sensor wires hooked up backwards (Positive to Terminal 15 on Relay, Negative to Terminal 14).
Will do some testing tonight.
Might want to move this thread to troubleshooting ms1
81 931
-ms1 v3 w/edis
-ms1 v3 w/edis
