Correct.knastenrad wrote:With a MS3X , 36-1 triggerwheel and LS2 coils in wastespark , i do not need a cam sensor right?
just set the :
"Number of Cylinders" to 12
use the 6 first spark outputs
and wire 2 and 2 coils(the ones that are at TDC at the same time) to the spark outputs?
Jaguar V12
Re: Jaguar V12
Re: Jaguar V12
great!
helping a buddy in the planning here to convert the stock EFI to MS3X
Re: Jaguar V12
I'm getting ready to install an MS3/3X on a 92 XJS and was wondering if anybody has pictures of how they are setting up the 36-1 trigger wheel on the crank pulley. I've got a couple of different ideas of my own but would just like to see what other folks are doing.
Thanks!
Jeff
Thanks!
Jeff
Support the developers!
Re: Jaguar V12
Dear Jeff,
See http://www.msruns.com/viewtopic.php?f=92&t=22941
and
http://www.jag-lovers.org/snaps/snap_vi ... 1352157009
plus my other photo albums on the jag-lovers site
I have since changed my cam sensor for a standard Ford VR sensor and machined the crank pulley with 35 teeth instead of using a trigger wheel. I did this to get the trigger "wheel" closer to the block and so the bracket holding the VR sensor would have less opportunity to flex.
You setup will be no doubt be different as you will have a different combination of belts which you need to avoid.
kind regards
Marek
and
kind regards
Marek
Re: Jaguar V12
Thanks got some good ideas
Jeff
Jeff
Re: Jaguar V12
Hi, I'm new here so please don't shout at me if I say something silly!
I have a V12 E type which I would like to MS so looking for any information which will make my journey easier, I have a set of pre HE manifolds with injectors and throttle bodies as a start to the project which I am currently refurbishing, don't yet know the condition of the injectors but I may be advised to change them any way for something different?
The other area I've been looking at is mounting the trigger wheel and pick ups, now I know everyone seems to mount them at the front pulley but has anyone thought of adapting a distributor to mount them, yes I know it turns at half speed but surely 2 missing teeth 180 degrees apart would take care of that, they'd be in a more protected environment and less likely to be damaged by the belts?
Looking at previous posts it looks like The MS is developing so that less additional parts will be required to complete a working system on the V12, is this right or am I reading too much into the comments?
Any way that's it for now.
Regards
Graham
Regards
Graham
Re: Jaguar V12
It can be done but is less accurate. There are several OEM systems that did something like this - usually with a "dual wheel" mode and no missing teeth. (Example: The Nippondenso CAS)Graham wrote: The other area I've been looking at is mounting the trigger wheel and pick ups, now I know everyone seems to mount them at the front pulley but has anyone thought of adapting a distributor to mount them, yes I know it turns at half speed but surely 2 missing teeth 180 degrees apart would take care of that, they'd be in a more protected environment and less likely to be damaged by the belts?
These have been done for a while - bank to bank ones have even been done with MS2. MS3 can run full sequential on a V12 with either add on injector driver mods or MS3-Pro.Looking at previous posts it looks like The MS is developing so that less additional parts will be required to complete a working system on the V12, is this right or am I reading too much into the comments?
Re: Jaguar V12
Perhaps the main reason for using a crank trigger is the signal is extremely accurate, and consistent. A dizzy usually has a chain drive somewhere which can stretch and gears which have backlash.
Have you asked Trigger Wheels in the UK about fitting a wheel and trigger to your Jag V-12? I'm willing to bet several have done just this.
Re: Jaguar V12
Thanks a lot for the quick replies, just the kind of constructive information I was looking for, my question about alternative trigger wheel position was purely from a bit of lateral thinking.
Can someone maybe point me in the direction of more info re injector drivers so I can do some more reading and whats MS Pro?
Graham
Graham
Re: Jaguar V12
Re: Jaguar V12
Just spent a couple of days reading up about MS3Pro, what a piece of kit!! all I could wish for and more, letter to santa in the post, still got quite a shopping list before I can make a start.
Graham
Graham
Re: Jaguar V12
Hi Graham,
what about your project?
Keep us informed!
I'm restoring an E Type S3. I've bought a EFI XJS V12 and I'm interested with information on the use of Megasquirt for this engine.
Cheers
Keep us informed!
Cheers
Re: Jaguar V12
I'd thought about getting a HE V12 engine from an XJS and just swapping it in but then decided I'd like to keep as much of the car original so decided to do an EFI conversion instead, other projects are taking priority just now but research is still going on in the background.
Graham
Graham
Re: Jaguar V12
@ Tobmag
Would very much like to see your (or anyone's) standard advance map for pre-HE V12.
Tried to PM you but no details shown. Could be because I'm an newb or could be you haven't entered any.
TIA,
Wilson Logan.
www.xj12l.com
TIA,
Wilson Logan.
www.xj12l.com
Re: Jaguar V12
Subscribed. about to begin the same... with 6 liter motor from a 95 xjs along with 4l80e gearbox. going into a 1963 Mk10 sedan.
Building my shopping list now.
for simplicity sake and to keep the budget under control, I plan on keeping the twin coil fixed distributor in place and installing a 36-1 trigger wheel in place of the original (damaged) trigger on the front crank pulley
any thoughts on that combo?
Re: Jaguar V12
Do a bit of reading on Dual Dizzy mode; you'll need two high-energy coil drivers (BIP373 or similar).jhkm12345 wrote:Subscribed. about to begin the same... with 6 liter motor from a 95 xjs along with 4l80e gearbox. going into a 1963 Mk10 sedan.
Re: Jaguar V12
Re: Jaguar V12
Hi.
No problem I can share my maps. Just PM me a email adress.
I would remove the dizzy as I have done on my XJ12 pre-HE and run wasted spark.
Its not a dual dizzy as on BMW but a dual coil kind of thing.....
In my XJS Im running a MS3 and a GPIO with megashift code to control the transmission
Br//Tobmag
Br//Tobmag
Jaguar XJ12 MS2 V3
XJS V12 MS3/MS3X + GPIO Trans cntrl over CAN
(Google translate will be your friend )
Re: Jaguar V12
New here, I've been looking for Jag V12/Megasquirt info for some time, this thread still seems to be about the most comprehensive....
I'm beginning a build of a pre-HE racing engine. Base motor is a 5.3, but I'll probably end up using a 6.0 block/crank/rods, custom pistons, pre-HE heads, steel liners. Bore will be 96mm to give me a ~7 litre motor... On the top, I've thrown away the Jag inlet system and am using BMW independent throttle bodies (from an M3, 2 sets), mounted on custom adapter plates that I've designed/machined myself. I plan to run COP (using Mazda RX8 coils, they seem to be the lowest profile COPs I can find; I may use a "coil near plug" setup with short leads) and fully sequential injectors.
I already have an MS3 + MS3X which was originally going to go on a Lexus V8, but will now be used in the Jag project instead.
Theoretically, I should be able to get 700bhp out of this thing. I'll be happy with anything over 500, and over the moon if I get over 600; and probably in a LOT of trouble if I get over 650
The engine is going into a Jag XJS, which is already stripped & in the process of being de-rusted, prior to re-assambly as a race car. I have an old Indy car clutch I'll be using (4.5" 4-plate), custom 2-part flywheel, original auto box flex plate, probably a Tremec 5-speed box, standard XJS diff. I plan to have a lot of fun in this thing, and I've got about 2 years of my original 3 year timetable left to build it...
The whole Megasquirt thing is new to me, so any help I can get using it, I will take. For example; I can obviously use any trigger wheel I like, so what would the suggestion be - 12-1 seems a bit coarse, but 60-2 seems a bit fine? 36-1 maybe? I should be able to fabricate my own cam sensor wheel/sensor bracket, so no worries there, is there any point in having 2 cam sensors (as with the Lexus, for example)?
Anyway, I'll have a million questions, I'll probably start a new thread for those, I just wanted to chime in here to say there's another V12 on the go
