msextra upgrade
msextra upgrade
This my first post, I hope someone can help.
My ms2 v3 works perfectly on the b&g code but
When load msextra I can't get a tach signal from the stim
It won't start the engine....so I go back to b&g code and everything is fine again.
I have not tried tuning it yet as it has itb,s and need alpha n to start tuning
Any help appreciated cheers Phil.
Re: msextra upgrade
For help here...
Re: msextra upgrade
I think this is it
Re: msextra upgrade
That one is B&G code.
Graduate of EFI University.
Re: msextra upgrade
sorry for late reply ...b&g code ..doh i am still getting my head around all this.
my daily drive is playing up so i,ve not had time for the project.
i have reloaded msextra and have the same problem.. no tach signal from the stim.
i will include an msq......the right one this time
appologies phil
appologies phil
Re: msextra upgrade
Your tooth #1 angle won't be zero, not sure that would cause no rpm signal on the stim however. Can you take a tooth and trigger log (composite log) under Diagnostics and High Speed Loggers tab?
Re: msextra upgrade
thanks elutionsdesign for taking time to look at my msq.
i am not using a crank trigger, just vr. i realise the stim has difficulty doing this
but it worked well with the b&g code.
i will jumper the ms for optical and try that, if i have to go down the ignition road
i will , but i wanted to get fuel right first.
thanks again for your help cheers phil
Re: msextra upgrade
Msextra is now up and running..I just needed to select fuel only in ignition settings now the stim
Sends a good strong tach signal to the ms and the engine starts, now lots of fun tuning thanks
To all .... Phil.
To all .... Phil.
