That's nothing to do with TunerStudio, it sounds like maybe you changed firmware version?capri v8 driver wrote:i got a feeling that the latest version of tunerstudio is different.
Made good progress this afternoon, shielded wires are in place, fan wiring is done and working and started with making a box for the ford ecu connectors. with some luck tomorrow evening all is done.capri v8 driver wrote:To day and tomorrow I will tidy up the wiring first, box the ford connector and find a good spot for the ecu, swap and separate the cam wires for new shielded wires, replace the 20 + years old fan wiring and 40 years fuse box for a modern one.
Greets Paul.
I have seen those vids before. I guess there is some paint on the capri by now and you are driving it.
I wish it was so. The car actually looks _less_ complete now than in those vids as I decided to change the rear axle and chassis somewhat.capri v8 driver wrote:I have seen those vids before. I guess there is some paint on the capri by now and you are driving it.
What axle are you gone use?jsmcortina wrote:I wish it was so. The car actually looks _less_ complete now than in those vids as I decided to change the rear axle and chassis somewhat.capri v8 driver wrote:I have seen those vids before. I guess there is some paint on the capri by now and you are driving it.
My question, is it posible to delay the cam signal in tunerstudio or would it be possible to rotate the cam sensor slightly so that the signals of the crank and cam dont aligne to pervent a sync-loss?jsmcortina wrote:There are false triggers on the cam input.
My suggestion - simplify things. Get the engine running with semi-sequential fuel and the cam sensor unplugged.
THEN... once you know that the engine can start and run, you can tackle stage two of adding the cam sensor and sequential fuel.
Note, that that VE table has no effect on the first stage of starting. That is controlled only by cranking timing and cranking pulsewidth. From the one startup datalog you posted it looks like the engine is bursting into life and then dying due to the sync-loss. My suggestion above ought to resolve that.
I _think_ the reason for the sync-loss is that the cam tooth/sensor is positioned at an unfortunate angle so the pulse aligns with the EDIS PIP signal and is sometimes before and sometimes after that edge.
Turn the cam sensor so it is ~20 degrees later or earlier.capri v8 driver wrote:My question, is it posible to delay the cam signal in tunerstudio or would it be possible to rotate the cam sensor slightly so that the signals of the crank and cam dont aligne to pervent a sync-loss?
