Greetings; I was directed here after posting on the MicroSquirt forum. I'm considering a MicroSquirt for a custom installation of a Mazda Renesis rotary engine. I don't need to control the stock throttle-by-wire throttle or the intake manifold tuning valves (will be using a basic no-frills throttle body & custom manifold), but would like to do sequential injection, if possible. This is a 4 port engine, with 4 injectors (2 per rotor). My understanding is that the MicroSquirt will work, as long as MSExtra code is loaded to support the 36-2-2-2 crank wheel.
If anyone's already set up a Renesis using a MicroSquirt & would be willing to share their setup parameters, I'd be grateful.
Thanks,
Charlie
MicroSquirt on Mazda Renesis?
Re: MicroSquirt on Mazda Renesis?
the microsquirt with the extra code would work on wankels engine but you are not going to have sequential injection if you want sequential injection you have to go ms3.
Thanks; after thinking about it a bit, I can see that.
If anyone's got a file showing all their setup parameters, I'd love to have a look at them. It's hard to get any idea on how difficult it will be to set up a system, when I don't have one to play with.
Thanks,
Charlie
Thanks,
Charlie
