Ford 5.0 windsor hints and tips?
Click here to enter
Contact a Forum Administrator
the_buster
Post by the_buster »
I have ordered my MS3 with expansion and I will be installing it on my Ford 5.0. Can anyone give me some tips on the 302 Windsor? I am very keen to delete the MAF!
Re: Ford 5.0 windsor hints and tips?
Post by Matt Cramer »
If you're using the TFI ignition, there are a lot of tips here:
http://www.diyautotune.com/tech_article ... ng_5_0.htm
the_buster
Matt Cramer wrote:If you're using the TFI ignition, there are a lot of tips here:
thanks,
I did read that a while ago ;)
subwoofer
Post by subwoofer »
Why delete the MAF? The MS3 code works like a charm and makes for easy tuning once you understand how it works.
Might even get VEAL support soon!
Joachim
1974 Jensen-Healey
2014 Ford Fiesta EcoBoost
the_buster
subwoofer wrote:Why delete the MAF? The MS3 code works like a charm and makes for easy tuning once you understand how it works.
Because my intake is 3 inch in diameter up to the throttle body but as it gets to where the MAF housing is, it shrinks down to an absolute joke of a size near 50mm. In my opinion nothing should be on or in that intake tube other than air. besides I'm buying a blower soon :D
subwoofer
Post by subwoofer »
Get a bigger MAF, they exist in sizes supporting 1000+ bhp...
Joachim
1974 Jensen-Healey
the_buster
subwoofer wrote:Get a bigger MAF, they exist in sizes supporting 1000+ bhp...
Yeah I noticed that but I'm on a budget and would rather put the cash somewhere else. Or could someone explain in greater detail the benefits of a maf for tuning.
Ollie8974
Post by Ollie8974 »
These are the Ford Cam sensors if you are going sequential injection and ignition.
I don't know which is the 5.0 sensor, but you can see the different diameter.
Use a Ford EDIS 36-1 trigger wheel and sensor.
subwoofer
Post by subwoofer »
For a low-buck solution to a higher flow MAF solution, take the sensing element from a smaller Bosch MAF and mount it in whatever size tube you want. Beware that a 65mm MAF flows more than enough for most applications, making it too large only kills resolution at idle and cruise. Bigger is not always better.
Joachim
1974 Jensen-Healey
the_buster
Ollie8974 wrote:These are the Ford Cam sensors if you are going sequential injection and ignition.
Yeah! Thanks I was looking for those :)
won't I still be able to run sequential with the TFI? I thought it was just like a dual trigger dizzy.
the_buster
subwoofer wrote:For a low-buck solution to a higher flow MAF solution, take the sensing element from a smaller Bosch MAF and mount it in whatever size tube you want. Beware that a 65mm MAF flows more than enough for most applications, making it too large only kills resolution at idle and cruise. Bigger is not always better.
Thanks you!
I will try it this weekend.
