Unable to go online
Unable to go online
Good day,
I have a microsquirt ECU and completed installing it last night. I was going through calibrating the respective sensors and after testing the injectors the laptop freezed and since then i haven't been able to go online to turn off the injector testing mode, which has resulted in every time i turn the ignition on the injector pulses 400 times.I have gone into project properties and when i test the port it fails. What should i do next to correct this problem. Also at the top of the tunnerstudio it says go online for firmware version.
Regards,
David
Regards,
David
Re: Unable to go online
Now might be a good time to load up the MS2/Extra firmware. You'll need to use the BOOTLOAD wire.
See the "Megasquirt-2 setting" up manual from the Manuals link above.
Thanks, did as suggested. after entering settings i am now getting on my gauge cluster " Settings changed that require a power cycle to take effect". What does this mean and where do i go to correct this.
Regards
Regards
resolved.
For reference, this is covered in section 2.12.8 in the Megasquirt-2 Setting up Manual. See the Manuals link above.
Greetings,
On my gauge cluster in red "Not rpm synced" i have changed the rpm limits and it still wont come off. where exactly should i go to get the rpms synced?
Are you getting RPM or not?
Is this a new project (I thought it was?) or an update. If it is an update, then be sure to read point 17 in the RELEASE-NOTES.txt that comes with the firmware.
yes i'm getting a reading when starting the car. but the rpm speed wont pass 150, so it wont crank. Yes its a new project.
It is likely best to start a new topic with a full description of your install and attach MSQ and datalog of an attempted start. See "Read help page here."
