Long time lurker, slow learner.
Click here to enter
Contact a Forum Administrator
bradyzq
Re: Long time lurker, slow learner.
Post by bradyzq »
Yup, the first two docs show a vr cam sensor. They even show the waveform to remove any doubt. But all the Bosch cam sensors I've seen have been Hall, as mentioned in the last doc.
Can you just test it? Voltmeter, or ideally a scope, connected across the 2 pins of the sensor. Then wave a piece of steel past the sensor tip. If A voltage is generated iit's vr. If not, the sensor is a hall, or its broken.
Cheers, Brady
Audi 4kq MS1E,
Audi Quattro, 034 IIc
Audi 200qa20v
Audi 5ktqa
Datsun 240Z
billr
Post by billr »
"A two wire Hall effect THEORY from another forum - has anyone heard of such a thing?"
I don't know about automotive ones, but they are certainly available for industrial applications.
Post by Matt Cramer »
A two wire Hall effect sensor would most likely be using the body as the third (ground) wire.
billr
Post by billr »
No, they don't use the case as a "third wire", they are true 2-wire. Kind of like a current-loop system. I'll look for info, I think Allegro makes some chips and Turck the assemblies.
billr
Post by billr »
The Allegro A1244 is a 2-wire Hall device. (Note that it has three leads, but one is "NC")
