i did a question past week about a chevy 5.3 running with ms2 and i bought a ms2 for this setup some days ago.
so now, i want to know if megasquirt is capable of running nissan rb26dett.
it will need 24-2 cas from diyautotune ?
ms2 ? ms3 with expansion card?
thankyou for your help.
rb26dett + ms3 + ms3x ?
Re: rb26dett + ms3 + ms3x ?
Megasquirt is capable of running it, sure. Any variant of the MS family can run it, you have to decide what you want to use for rpm input and possibly cam input. I personally like using a CAS for cam only and using a crank trigger for rpm. That way you can run full sequential but that's not a need, its a want.
Graduate of EFI University.
An MS3 with MS3X can run the stock CAS, no disc swap required. See this link for how it's done.
http://www.diyautotune.com/tech_article ... b25det.htm
thankyou matt.Matt Cramer wrote:An MS3 with MS3X can run the stock CAS, no disc swap required. See this link for how it's done.
