Tooth logguer review, sync lost reason
hi
someone can teel me if those logs have good signal from the crank sensor?
sometimes, i have a sync lost causing a misfire,
at idle, and one time at 2500 rpm aprox.
can someone give some tips to tuning the vr pots?
regards
regards
Re: Tooth logguer review, sync lost reason
I didn't see any loss of sync in the logs you posted.
yes, you are correctMatt Cramer wrote:I didn't see any loss of sync in the logs you posted.
but sometimes, it happens, 1 time in 10 minutes for exemple.
i just need to know if this kind of values are good for a 60-2 wheel ,
regards
The readings in the logs you posted are good.
But if sometimes they are not good, it would help me to see a log of HOW they are not good.
Matt Cramer wrote:The readings in the logs you posted are good.
Maybe today im going to put the car on the dyno for a last time, and ill do some logs,
Regards
there is the logs that i have done
i just get the lost sync between 2500 - 3500 rpm
reason 2
someone can give me some tips to solve this?
another point, im having very noisy readings on the logs,
could be the computer? the aten rs232 cable?
and this readings are on the dyno, if im going to the road its worst, very worst.
reason 2
The composite log shows a noise pulse on the crank signal. Try the noise filtering settings.
ok this morning
i fixed the ecu on is place,
turn on the noise filter
i have done a few miles with the car and seems fine,
the problem of the noisy logs, persists, and with the car runing on the road, its worst than on the dyno.
i thing my EEEpc mono Core laptop dont have speed for this.
regards
regards
