Pin output error
Pin output error
I know that the problem I am having has to be a small mistake I have made in my settings, but I'm stuck. I haven't gotten the car tuned yet, however I have decided to switch from speed density to a MAF. I connected my MAF to the "Digital Input Frequency 2) pin out. I set that in the MAF options, and it tells me that, "Conflict on spare ports output pin - pin already in use by - MAF." It will not sync to my car because of this. Does anybody know where I went wrong? Thanks for any help!!
1994 Camaro
LT1, 383, D1SC Procharger 16 psi
LS1 ignition, 2014 Vette MAF
Re: Pin output error
You have it set as an input on maf settings, but also set as an programmable on/off output under the advanced engine menu
