Pressure sensors for fuel/air/oil
Re: Pressure sensors for fuel/air/oil
I believe this is the correct pigtail for the GM 12616646 sensor
https://www.eficonnection.com/eficonnec ... ItemId=578
I case anyone is looking.
http://www.buildpics.org/
Any update on the gm sensor
Took off the eBay cheapie brass sensors today, and fitted the genuine GM 12616646 sensors.
The 150psi brass sensor checking oil was starting to leak around the outside. The other 150psi bass sensor of the fuel rail (E85) looked ok.
Im sure the GM sensor will work fine with oil, but fuel/ethanol is unknown... guess ill find out
Finally tracked down the sensors that I'd mentioned, after they vanished while moving.
I can test them if you're still interested, but it sounds like you found a solution.
Josh
-greasy fingered tinkerer
any updates
The genuine GM 12616646 sensors are working great for fuel (e85) and coolant for me so far.
Finally had my brass one start leaking.
Good find on the gm sensor, assuming its 1/8npt?
Still need a decent ~500psi for my clutch line sensor thats resistant to brake fluid.
That might work: http://www.digikey.com/product-search/e ... 23-1141-ND. It might be a bit big being a 1/4NPTPaul_VR6 wrote:Still need a decent ~500psi for my clutch line sensor thats resistant to brake fluid.
That's a fair price too.
I thought so too.
how long you been using the sensor fuel(e85).MWPau wrote:The genuine GM 12616646 sensors are working great for fuel (e85) and coolant for me so far.
Hmm, about 3 months.
ok good. time to order 2 one for oil pressure and one for fuel.
does anyone have the part number for just the connector for the gm sensor,also the settings to use with this sensor.thanks
At the top of this page I posted alink for the fuel pigtail.
i know but i just want the connector.
it's in the digikey datasheet page 3/6elturbonitroso wrote:i know but i just want the connector.
can somebody confirm if this its the right calculations to use with this sensor.thanks
0v=-16.25
5v=146.25
0v=-16.25
5v=146.25
Close enough.
Im using -16.5, 145.3
ok.thanks
