I've been looking at fuel tank designs for an EFI system and the range of options is somewhat limited for obscure vehicles. Pondering the requirements, I had an idea that I suspect must be flawed, given its simplicity. Seeking opinions from the Collective as anything to do with flammable liquids isn't to be taken lightly.
Stainless steel kitchen sinks come in a variety of sizes and shapes. You can find used, under-mount sinks for a very low price. Why not adapt one for use as a fuel tank? The general idea is to take a sink that usually has a small flange and weld a flat plate over the opening. Of course, this plate would have openings to attach all the required bits, such as a sender, pump module, roll-over valve, vent, filler, etc. Weld the drain opening shut or add a sump there for the fuel pump to sit in. Weld in baffles if needed to the sink.
For safety, attach a second plate under the sink and bolt it to the top plate.
What's wrong with this decidedly Rube Goldberg approach other than the mixing of kitchens and automobiles? The cost of the top plate could be high but perhaps not, if sourced cleverly.
Fuel Tank DIY - throwing the kitchen sink at it (literally)
Re: Fuel Tank DIY - throwing the kitchen sink at it (literal
How about using two sinks, avoiding the cost of getting a sheet. Two of them, joined at the flange like a belly-band, would probably have a better volume for a fuel tank
I had considered that but it may be difficult to attach the fittings; too thin. One could weld in thicker flanges, I suppose.billr wrote:How about using two sinks, avoiding the cost of getting a sheet. Two of them, joined at the flange like a belly-band, would probably have a better volume for a fuel tank
I like the way Bill thinks! I have always been a big Rube Goldberg fan!!!
Seriously, (something unusual for me) I also thought that 2 sinks might be just the ticket!
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
I've seen this done before. Wish I had taken a picture. From what I remember, the guy had cut a 2 basin sink in half. He welded the 2 halfs together. He welded plates over the drains to attach the fill and other fittings.
Sam
Sam
___________________________________________________________
If nothing breaks, you're not trying hard enough...
Datsun 280Z
ITB
Turbo
MS3 + MS3X
Datsun 280Z
ITB
Turbo
MS3 + MS3X
I think one of the cars at the Grassroots Motorsports $2013 Challenge - the Civic that was impersonating a Subaru - used a kitchen sink fuel tank.
