Although I haven't posted on the forum before, I do have some (ok, a lot of) car, engine and tuning experience.
Looking for any help you can provide with this project, feedback on my plans and so on.
The car:
- 1968 Jaguar 420, with a 4.2 liter, straight 6, XK engine, with dual carburator setup (3rd "carb" for startup enrichment) and a manual transmission. Car is currently my daily driver and performs well but starting to have carburator issues.
First step:
- Megasquirt v3.0
- custom intake manifold
- 6 2007 Suzuki Hayabusa 1300 throttle bodies (3 double ones), spacing is almost exact the same as jaguar cylinder spacing
- 6 60lbs injectors (1 per intake port) and yes I know these are big
- Original air cleaner (modified receiver dish)
- Single fuel pump feeding from 1 tank (the car has 2 30l fuel tanks)
- Distributor point trigger for ignition
- Megasquirt to control the coil firing
- Convert input signal to EDIS trigger
- Replace coil for coil pack, going to wasted spark, spark control from Megasquirt (yes I have the right hardware to do this and modded my board)
The intake is mostly complete, I need to finish the mounting of the intake runners into the coolant passages. The attached pictures are from the intake being machined, I started with a standard intake which I modified and added new straight through runners onto.
I've got all the parts already purchased or at least identified (fuel safe 50mm hose is last item to be purchased).
I have a full "mule" engine sitting in the shop to test my setup on, I can do all the sensors, wiring and test fitting on this engine before final mounting in the car. This test engine can not be run in the current setup.
I do have a full (minus computer) EFI setup from a Jaguar XJ6 series III which has the "same" engine as my car but with an awful early '80s EFI system, I decided that making a throtlle body setup was more fun and would result in a better performing EFI system, if that is true I'll find out soon enough.
The size of the throttle bodies is by far good enough, the airflow calculation I use for situations like this is displacement times redline rpm for each engine, the numbers should be close. In this case. I have 1.5 throttle bodies (6 tb's from a 4 cylinder) for a 1,300cc engine doing 15,000rpm redline going into a 4,200cc engine with a 6,000rpm redline.
Resulting calculations is 1.5 * 1.3 * 15 = 29.25 (Hayabusa throtlle bodies) and the XK 4.2 liter 4.2 x 6 = 25.2 or in other words if anything the throttle bodies are slightly big.
The injectors at 60lbs are big, possibly overkill, but I had them left over from a blown v12 469cu project that I sold before the EFI was installed, in simulation with EFI analytics I can stress them to 55% duty cycle, I think that will be fine.
