Ever since Linux MINT 11 I have not been able to connect to a MS3X via the serial port or via usb. Looking through the files in TunerStudio if found TunerStudioAppDebug.txt.
I found this error which may explain the serial port problem.
RXTX version mismatch
Jar version = RXTX-2.2pre1
native lib version RXTX-2.2pre2
IS this a problem and if so how do I fix it?
CLS
serial port under linux does not work
