New to the forum...sr20det
Have a 71 Datsun 510 that I just finished installing an S13 SR20DET engine. Purchased the MSPNP2 a couple of months ago and just curious to see if anyone is running an SR20DET with a MSPNP2. I am at the point where it is cranking, but not successful at getting it running yet.
As far as engine components, I have 550cc injectors, splitfire upgraded coil packs, t3/t4 turbo...
Re: New to the forum...sr20det
You do have a computer connected and running with tuning software while you're cranking? Can you see rpm?
Graduate of EFI University.
MS2 won't work with the stock CAS trigger disc you need this: http://www.diyautotune.com/catalog/50-m ... p-472.html
Support the developers!
That is included with the MSPNP for these cars, and is covered in the installation documents, along with setting the timing. The timing is set correctly, right? Just checking.prof315 wrote:MS2 won't work with the stock CAS trigger disc you need this: http://www.diyautotune.com/catalog/50-m ... p-472.html
Can you post a data log of an attempted start and a copy of your tune file?
Here is a copy of my data log....
Battery is pretty low, not much else jumped out at me.
Please check timing and post the MSQ.
Here is what I am using...timing is correct
This doesn't look like a standard MSPNP tune. Try rescaling Required Fuel; it's a bit low for your injector setup. Also, change the injector drivers setting to "Additional Drivers"; MSPNPs have four injector drivers, and setting this to "Standard Drivers" turns off half the outputs.
it is the msq I downloaded from the DIYautotune website...
Do you have a proper base tune for the s13 sr20det red top??
Use this one: http://www.megasquirtpnp.com/downloads/ ... T_331a.msq
OK, installed the msq you told me to download. Here is the datalog.... thanks for your time and help by the way bro....
Still does not start.
Is the IAT sensor reading accurate?
How is the timing when checked with a timing light?
finally got it running...we had to give it a lot of timing so we are going to check everything again. I will keep you posted on the progress. Thanks for all your help so far....
Any updates on this tread? How did it go with sr20det and your setup that you have?madsr510 wrote:finally got it running...we had to give it a lot of timing so we are going to check everything again. I will keep you posted on the progress. Thanks for all your help so far....
