Using MAP signal to run sequential injection
How do I know if the microsquirt has switched to sequential from batch? I don't see an applicable indicator in the gauge cluster.
EDIT:
Okay, so I am NOT running in sequential. I have changed a few criteria but can't get it to run in sequential. I am at a loss at this point, can you guys take a look at my files/logs and see if you notice any errors?
EDIT:
Re: Using MAP signal to run sequential injection
It you look at status1 in a data log 8 would be half sync so batch and 136 would be full sync sequential the status fields should be covered in the manuals
Not sure I follow. What is data log 8?grom_e30 wrote:It you look at status1 in a data log 8 would be half sync so batch and 136 would be full sync sequential the status fields should be covered in the manuals
There is a button on the dash that indicates half/full sync, however it lights full sync even though I am currently running in batch mode.
if you look at a data log you have saved, there should be a field to view called 'status1' if it =8 your half synced just using the crank sensor and if it =136 you have fully synced up eg using crank and cam/map phase. also in tunerstudio there should be the half/full synced indicator.
if your tune is set to use batch you should get full rpm sync off the crank sensor only.
Okay got it, thanks! I didn't know the indicator changed it's criteria based on injection mode.grom_e30 wrote:if you look at a data log you have saved, there should be a field to view called 'status1' if it =8 your half synced just using the crank sensor and if it =136 you have fully synced up eg using crank and cam/map phase. also in tunerstudio there should be the half/full synced indicator.
Well I turned on full sequential injection mode, using the map sensor. I am using on the Shadowdash screen, I am getting the indicators "half-sync" changed to green and reading "full sync" EDIT: it was the icon next to full sync I think. I am also getting the "not synced" indicator green and "synced". However I have a status1=8, then after idling for a while it changed to 9.
Sure would be nice if there was some detailed documentation on this stuff.
http://www.msextra.com/doc/pdf/html/Meg ... e-1.3.html page 60
that explains it, so status1 = 8 is rpm synced ( crank sensor )
status1 = 9 is rpm synced (8) & need burn you (1), you must made a change to the tune file.
So to verify, rpm synced=sequential? or is it really just RPM? I was on VEAL so that makes since for the burn required.grom_e30 wrote:http://www.msextra.com/doc/pdf/html/Meg ... e-1.3.html page 60
rpm synced status1 =8 is half synced crank sensor only full synced =136
So with those files above, it is now syncing, but I am also as a temp where is cranks longer before firing. I am seeing full-sync come up before the engine fires (yes status1=136). I'll have to see if this continues.
I confirmed if cranking takes a little long, it will detect the phase and run in sequential. If it fires up quickly, it never detects the phase. I have it set at 80kpa under "Phase Detect Threshold", I read the manual but it doesn't explain this very well. Does it try to detect the phase when running or only when cranking? I guess I can randomly guess as various values and see what happens.
I did some more testing, changing "Phase detect threshold" from 10 to 90kpa in 10kpa increments. It never fully synced if the bike fired up quickly and never synced after it was running, regardless of the phase detect value. Where to go from here? It seems like the phase detect method is only under cranking and therefore not terribly robust?
Do you have the registered version of TunerStudio? If yes, then record some MAP logs and see what's happening.
It might be that your engine is unsuitable to this phase detection method and you'll need to add a cam sensor. Or perhaps you have the MAP sampling angle set in the wrong place.
Thanks for answering James!jsmcortina wrote:Do you have the registered version of TunerStudio? If yes, then record some MAP logs and see what's happening.
Yes I have the registered version and my Map sample window looks good. I have a consistent ~40kpa vacuum at idle.
As you are getting a good 40kPa, then I'd think that your phase threshold should be set to somewhere around 50kPa.
The phase detection operates during cranking and run until a "yes", "no", "yes", "no" pattern is found or too many failed matches occur.
Code: Select all
if (synch & SYNC_SEMI2) {
/* SEMI2 here means that we've synced to the crank, but have
yet to confirm cam sync. We are still running wasted COP and
are looking to match an on/off/on/off cam pattern. */
ls1_sl++;
ls1_ls <<= 1;
if (flagbyte1 & flagbyte1_trig2active) { /* happens when the MAP was below the thresh */
ls1_ls |= 1;
if ((ls1_sl > 3) && ((ls1_ls & 0x0f) == 0x05)) { // i.e. 0101
synch &= ~SYNC_SEMI2; // found cam, stop WCOP of dwells
outpc.status1 |= STATUS1_SYNCFULL;
} else if (((mapadc_thresh == 0) && (ls1_sl > 10))
|| (mapadc_thresh && (ls1_sl > 100))) {
/* Failed to receive matching pattern, cam input faulty */
/* 10 revs allowance on normal electrical cam sensor
100 revs for map threshold sensing in case operator starts at WOT */
You say it operates during cranking...I get 40kpa at idle, but during cranking I'm in the 85-95kpa range. It just doesn't pull that much vacuum during cranking. I did have it sync when set at 60kpa though....jsmcortina wrote:As you are getting a good 40kPa, then I'd think that your phase threshold should be set to somewhere around 50kPa.
JamesCode: Select all
if (synch & SYNC_SEMI2) { /* SEMI2 here means that we've synced to the crank, but have yet to confirm cam sync. We are still running wasted COP and are looking to match an on/off/on/off cam pattern. */ ls1_sl++; ls1_ls <<= 1; if (flagbyte1 & flagbyte1_trig2active) { /* happens when the MAP was below the thresh */ ls1_ls |= 1; } if ((ls1_sl > 3) && ((ls1_ls & 0x0f) == 0x05)) { // i.e. 0101 synch &= ~SYNC_SEMI2; // found cam, stop WCOP of dwells ... outpc.status1 |= STATUS1_SYNCFULL; ... } else if (((mapadc_thresh == 0) && (ls1_sl > 10)) || (mapadc_thresh && (ls1_sl > 100))) { /* Failed to receive matching pattern, cam input faulty */ /* 10 revs allowance on normal electrical cam sensor 100 revs for map threshold sensing in case operator starts at WOT */
From that code snippet you can see that it will try to find the phase for the first 100 revs before it gives up.
Hmm, I would think it would sync without issue then. I wonder if it's possible my map sensor is too far. It's about 2ft of hose so if I calculate that right, the lag is about 16 degrees. Can't imagine that would make a difference though.jsmcortina wrote:From that code snippet you can see that it will try to find the phase for the first 100 revs before it gives up.
Is there any kind of datalogged parameters that could determine the failure mode of the sync?
Could the type of detection method make a difference? (Rising/falling edge, polling)?
