hello all, maybe not directly related to MS work so apologies for no msq or datalog, but I'm going the DIYEFI route on my '78 924, and luckily, I have access to a very sexy waterjet, and it would be very easy to fab my own trigger wheel. Does anyone have a recommendation for the best metal and coating/treatment to use? mild steel w/ cad-dichromate? bare alum? would love any thoughts on design as well. I'm sure I will have plenty of questions regarding tuning soon, but for now starting w/ just the hardware.
thanks in advance,
k
trigger wheel fab
Re: trigger wheel fab
Make sure it is ferrous.
Because of minimum set up cost, any commercial coating / treatment is going to be expensive for a one off. I would suggest spray can painting.
There are those home powder coating kits.
Yes, Ferrous metal, 1/8 inch thick.
Can the trigger wheel be mounted to the back side of the harmonic dampener.
Other wise all the pullies will need to be space out to properly align.
thanks for the tips; is there strong advantage to the standard ferrous material and hall effect sensor setup over lightweight alum. and an optical sensor? Is it mostly a durability issue? Ease of install?
keithiopian wrote:maybe not directly related to MS work so apologies for no msq or datalog, but I'm going the DIYEFI route
I hadn't spotted that.grom_e30 wrote:keithiopian wrote:maybe not directly related to MS work so apologies for no msq or datalog, but I'm going the DIYEFI route
User deactivated. EDIT: and re-activated after a misunderstanding was cleared up.
